LSD problem
Old Jul 23, 2003 | 05:18 PM
BigBlue's Avatar
LSD problem
I just replaced my rear axle fluid about 200 miles ago. First time in 37,000 miles. I didn't add any LSD fluid. I filled it to about a 1/4" below the fill hole. For some reason now, it's acting up. It doesn't chatter or anything, but it takes a lot longer for the other tire to kick in and start spinning. I can go around a turn and you'll hear one tire start spinning. Especially if the ground is slightly damp. Should I take the truck to Dodge and see if they won't fix it for me under warranty? Why is it doing this now? I've never had a problem with it until now. I didn't use synthetic. I used Pennzoil 80w-90 (I know it's 80W something). Should I change fluid to something thicker or something? The old fluid was extremely black and thin. Thanks for the help yall.
Old Jul 23, 2003 | 06:02 PM
Mexstan's Avatar
Re:LSD problem
Try ingesting some LSD and then you will not worry about the rear axle
Old Jul 24, 2003 | 01:22 AM
BigBlue's Avatar
Re:LSD problem
I dont' know what the deal is. Tonight, I did a burn out and they both started spinning instantly. So I don't know. I'm going to try and add just a little FM and see if that helps.
Old Jul 24, 2003 | 03:34 AM
geer's Avatar
Re:LSD problem
Mexstan
amartinson
Dec 10, 2004 04:04 PM
TON4FUN
Jan 11, 2003 11:09 PM
joel
Jan 11, 2003 02:29 PM
StakeMan
Nov 16, 2002 05:58 PM
