LP relocate... how to stop fuel
doing the LP relocate... started cutting into the line & fuel comes out... now i have about 3 gal in jug & still coming ... i unhooke one of the line to the tank, but can't get the other to disconnect
how do i stop the fuel from draining... nearly full tank of fuel!!!
when I did mine I opened up the fuel cap on the truck then cut the line fast and blew compressed and back into the tank, taking the prime away from the fuel pick up tube. if you don't have and air compressor you could use a long section of hose and bow in one end. make sure the one end that you blow in is always higher then the fuel cap. I would sugest using an air compressor. hope it help.
You might have to start over. Split open a 1 inch piece of 1/4" rubber fuel line and wrap it around your steel fuel line at the cut and secure it with a small hose clamp.
After you get the leak stopped, run out the fuel to 1/4 tank then raise the front of the truck and using jackstands to support the truck, restart your project.
thanks for all the responses... while i was waiting last night i was searching & found that i needed to blow in the supply line back toward the tank to stop the siphon effect... lost about 3 gal... luckily i caught most of it in a diesel jug i have
The line to the lift pump is full of fuel, and it will keep siphoning as long as there is fuel left in it. However, the line runs via tank top, so if you blow the fuel out of it, it will not leak anymore. I did exactly that myself, but I anticipated the leak and blew into the tube by mouth before I cut it.
Finish cutting quickly, slip on a piece of fuel hose and get the end above the tank fill neck. Blow into the hose until you hear bubbling in the tank. After this, there will not be draining from the cut line once you remove the hose.
It will be a good idea to suck on the new lift pump's output line, using a hose again, to prime the LP.
-P
-P
jentas
33
Mar 7, 2008 02:45 PM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
