lp question
Old Mar 7, 2007 | 09:08 AM
chris s's Avatar
lp question
i am adding a holley blue pump to my truck
do i bypass the in tank pump or plumb it in after
the in tank pump
thank you
2002 extended cab stock
Old Mar 7, 2007 | 10:16 AM
PaulDaisy's Avatar
How can you bypass? Are you dropping the tank and adding draw straw? If so, then bypass. If not, doesn't look like you have a choice but to plumb those two into the same line.
-P
Old Mar 7, 2007 | 11:11 AM
chris s's Avatar
am i just drawing through the intank or are both pumps wired
Old Mar 7, 2007 | 12:35 PM
blackdiesel's Avatar
Registered
you can't pull fuel though the in tank pump. I would run them both, that's the way I have dads truck and he has good pressure, and if the blue fails your not walkin
Old Mar 7, 2007 | 01:33 PM
chris s's Avatar
will do thank you
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
