Loud banging from front of the engine
Old Nov 18, 2006 | 07:18 AM
donhov's Avatar
Just a quick question? Have you checked the fluid damper? might it be loose or coming loose? Think it requires much torque and maybe you didn't have it seated when you tightened and it is coming loose now. Obviously I don't know but as you just replaced this item guess that is where I'd start looking.
JMHO Don
Old Nov 18, 2006 | 07:27 AM
derf464's Avatar
Ill second that, sounds like the dampener is coming loose, and allowing oil to get past the seal and leak out!!
Old Nov 18, 2006 | 06:23 PM
Rare1's Avatar
My first thought is the KDP, but has that ever happened on a 2004 model? Next I would guess a bolt has come loose inside the front cover. Clean up the oil and see exactly where the leak is for your next clue.
Old Nov 19, 2006 | 05:12 AM
2500's Avatar
killer dowel pin, used to line up timing cover on 12v. possible to back out possibly destroying your timing gears. fix is to either dimple hole or install a custom washer over pin.
if I had a loud banging noise coming from front of motor. I'd shutdown immediately! no way I'd drive 40 miles home, unless I was dead certain what's making the racket.
Originally Posted by gdh11
What is the KDP?
Old Nov 20, 2006 | 06:04 AM
2500's Avatar
if you can't isolate what's causing noise. you need to take to someone that can. an experienced mech may not have to tear motor down to tell you what's going on. they may not charge at all to do an estimate.
VS keep on driving and really hurt something bad.
I am not going to pay a shop to do a tear down to find a noise that isnt causing problems...yet. I have looked at everything I can think of and since the truck drives and runs fine I will just have to roll the dice. I cant afford to have my truck down any longer and if I blow it up then I will have to buy another motor I guess. I am getting nowhere and have too much towing to do to keep the truck down, for something that might not be a problem.
Old Nov 20, 2006 | 09:46 AM
dodgezilla04's Avatar
the front end is gear driven, no chains.
Old Nov 21, 2006 | 04:08 PM
XLR8R's Avatar
Something is loose, or you wouldn't hear the knock; it's probably stems from your recent upgrade to the FluidDamper and modded CP3.
marcar1993
Apr 10, 2015 06:58 PM
Cougsfan
Jul 31, 2011 07:33 PM
dieselthunder
Dec 14, 2008 03:44 PM
royalnine
Jul 28, 2006 12:01 AM
Hoss
23
Jul 9, 2003 05:45 PM
