lost fifth gear yesterday.
Old Feb 3, 2003 | 04:51 AM
Palmetto_kid's Avatar
yep...cruising down the interstate it just fell off. how much does it cost to get fixed? and where is the best place in eastern KY to get it fixed? thanks guys..<br><br>Hello to everyone!! Ive been away for awile. Ya'll take care.
Old Feb 3, 2003 | 05:19 AM
Copenhagenjunkie's Avatar
Re:lost fifth gear yesterday.
Sorry to hear that :'( :'(<br><br>If you can afford it, go with the 5600. Should run around 4-5k less if you do the swap. Call Monty @ Blumenthals in OKC. <br>405-236-4800. <br><br>It is worth the $$$$$, I just made my final payment to the bank for my tranny swap. It is expensive BUT You won't regret it ;D
Old Feb 3, 2003 | 07:52 AM
bulthisl's Avatar
It's not a big job.<br>First you got drop transfer case.<br>Then take rear cover off tranny<br>Get a repair nut and replace it .<br>The trick is it takes a special wrench to tighten the nut and it has to be 300 ft. lbs. tight.<br>Or if you opt. to change and update the output shaft.<br>But that is a little more involved.<br><br><br> : Eddie : 8)
Old Feb 3, 2003 | 09:38 AM
i cant do either. im up here in KY on a business trip. all my tools are back in Texas! :'( i wanna go home...
Old Feb 3, 2003 | 10:04 AM
rich's Avatar
dont know if they are close to you but mine went out in tenn. and i had it fixed at music city dodge in nashville. they got on it at 9 and had me out by 4;30. the gear was stripped so they had to replace it. it cost me 800. Since yours is probably simple it might be around 300 or 400 for everything. Good luck and happy hunting.
Old Feb 3, 2003 | 10:30 AM
Hired Gun's Avatar
What town are you in? I think TS performance could help in Bowling Green KY.
Old Feb 3, 2003 | 10:38 AM
bulthisl's Avatar
Where are you and how fast do you need it fixed ? <br>I may be able to fix it for ya.<br>It depends on how fast you need it.<br>PM me and maybe we can work it out.<br><br><br> : eddie : 8)
Purplezr2
15
Mar 8, 2011 07:56 PM
Totallyrad
Jan 21, 2007 11:49 PM
Johnny
Sep 14, 2004 06:55 AM
