Lost 5th gear again!!
Old Oct 25, 2005 | 05:28 PM
FMT's Avatar
FMT
Lost 5th gear again!! Please Help!!! 3rd time!! now what?
Driving home from work, lost 5th gear again in my 1998.5 dodge diesel. This is the 3rd time. First, time around 80,000. Second time, 135,000, now the 3rd time at 180,000. I just moved to Northern VA, D.C. area and really need the name of a good tranny guy in the area.
Any help would be greatly appreciated. I know the problems associated with this failure in the transmission. I just need someone up here to fix it again.
I live about 20 minutes from D.C.
Any takers???
Old Oct 25, 2005 | 10:19 PM
RCW's Avatar
RCW
Go to a medium duty truck transmission repair facility. Obviously, whoever has been repairing your transmission has not replaced the shaft with the version that is fully splined, or the nut would not fall off again. On one with the miles you have, any of the nut only fixes will fail within a few thousand miles because the edges of the OEM half spline are now worn off and creating a torsion bar that shoves 5th gear like a wedge and blows the nut right off the shaft.
Here is a truck repair facility fairly close to your area: Barr Freightliner, Rr 13, Delmar, MD 21875, (410) 896-3560. They can point you to a good transmission shop that can fix your transmission correctly.
Old Oct 26, 2005 | 09:50 AM
FMT's Avatar
FMT
Thanks,
I'll let you know what happens
Appreciate the response
LemonDodge
Sep 7, 2019 03:51 PM
mhuppertz
Apr 1, 2012 11:07 PM
dennisdw
Jan 17, 2012 08:48 PM
LemonDodge
Sep 16, 2010 07:33 AM
b84u
Feb 20, 2006 01:04 PM
