loss of all power 05 3500 5.9 please help
Old Oct 9, 2009 | 03:20 PM
loya 3500's Avatar
Exclamation loss of all power 05 3500 5.9 please help
its been a costly road to get where i am now still with a broke truck. my truck will run fine for a lil bit and say im going down the road 70 or so and go to pass a a car and as i push the pedal my truck just loses all power and blows black smoke with out the BULLY DOG. so stock and lots of black smoke? and wont go it just goes dow to 50 and wont pull its self out of a wet paper sac. so i took it to a dodge dealer as i was on the road to California in aaron berg AZ they sead it was my lift pump. so i let the replace it i got back on the road in 2days. the truck ran like gold still was blowing lots of black smoke? but i still drove it down the road got about 80mi and did the same stuff no fix so i took it the next dodge dealer and that the other told me to go to. so i took it and they had it for 2 weeks and i went home on a plane the.. there saying its my ECM comp id and there not sher either. BUT WHEN THEY ASKED WHEN THE LAST TIME I CHANGED THE SPARK PLUGS I TOLD THEM TO STOP TOUCHING MY TRUCK! so my older brother has it at his house now and im going to get it this friday ... but the truck has loss of power and blows black smoke stock and will stall out and wont start for at-least 20 min then its good to go for a bit then dose it all over.I replaced lift pump. but maybe some one has some in put
thanks pleas help
Old Oct 9, 2009 | 03:33 PM
cincydiesel's Avatar
Dead turbo, cracked intercooler? I lost an intercooler boot on the highway once and the truck fell on its face blowing smoke all over the place..
Old Oct 9, 2009 | 04:25 PM
rich's Avatar
put a boost gauge on it and check your boost also see if you can get any codes. also check your injectors
Old Oct 12, 2009 | 08:15 PM
loya 3500's Avatar
ok thanks for the in putt yall. ill keep yall up dated after i get dun hauling it back from california any one else with any ideas i would appreciate it thank yall.
Old Oct 12, 2009 | 08:45 PM
Hvytrkmech's Avatar
Wide open throttle with lots of black smoke and loss of power is an air flow/restriction problem. Check your air filter, intake tubes, and all boost tube boots and clamp connections. Check for torn boots and cracks in the tubes and CAC.
Old Oct 12, 2009 | 08:55 PM
1985cucv's Avatar
i would look at the boots too. or the plastic pipe on the intercooler from the turbo sometimes break
Old Oct 12, 2009 | 09:38 PM
Spooler's Avatar
Sounds like a blown plastic intercooler. Boost gauge time.
Old Oct 13, 2009 | 08:30 AM
loya 3500's Avatar
ok i hope thats it rather the turbo or injectors.. but i really wont know tell i get to california this sat and look at it. all be for i putt it on the trailer and drag it home to texas. and maybe fined the problem with what info yall have gave me. but either way its going home on the trailer cuz that wonder full thing we call diesel is not getting any cheaper lol
Old Oct 13, 2009 | 08:57 AM
rich's Avatar
isnt the 05 the one with the plastic intercooler sides
Old Oct 13, 2009 | 09:03 AM
DiezelSmoke's Avatar
I don't think its a turbo or turbo boost problem if you are having a black smoke problem. Loose of power yes, but black smoke no. You need turbo boost in order for for fuel pressure. I think your problem is the fuel rail high pressure switch. These have been a problem check for corrosion at the switch connector and make sure your connector is connected properly, if that looks ok then its probably the switch and you have to buy the fuel rail along with the switch as cummins has changed it. You can verify this with a low pressure code.
Old Oct 13, 2009 | 09:24 AM
rich's Avatar
when i blew the intercooler hose on my 98.5 it blew a ton of black under throttle. usaully if its a pressure issue idle and crankinking are effected
Old Oct 13, 2009 | 10:01 AM
loya 3500's Avatar
well im not positive on the plastic intercooler. have not really ever payed attention to it to be honest. but il fined out.. and yes the truck will idle fine and crank form what i know it was when i told the dealer to stop working on my truck. but its at my brothers house now has been for the last month just siting in the yard
thanks for the info
Old Oct 13, 2009 | 10:06 AM
loya 3500's Avatar
O and i know its not the turbo cuz when i was driving i thought the same. at first. but could here it spooling good still cuz i took the silencer ring out like 20k miles ago
Old Oct 13, 2009 | 12:22 PM
early 05's had the plastic intercooler.. I'm still living on borrowed time with mine..
Also, with a blown intercooler boot it will still blow black smoke.. Dont ask how I know.
Old Oct 14, 2009 | 09:24 PM
1985cucv's Avatar
yes i blew a boot on my old one and lets just say it filled the bed with smoke and then it rolled out of the back at 60 mph
