line leak
line leak
just called Cummins here...I have a small pin hole on the pressure side steel line that runs from the filter housing to the side of the IP... Are these guys nuts...They want $107.00 plus tax for this one foot piece of line.The leak is right where the pipe goes into the banjo.Could this be brazed??
I just had to braze the #6 injector line at the injector...be sure to use silver solder and some good acid flux, it'll hold fine! Yours is much lower pressure than mine and it works fine.
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
RoadDiesel
Jun 16, 2007 09:24 PM
Begle1
19
Aug 25, 2006 11:31 PM
