JBody, This might be a question for you.
Old Sep 5, 2007 | 06:31 AM
atch's Avatar
Can anyone tell me what resets the distance to empty on the overhead monitor?
atch
Old Sep 5, 2007 | 07:14 AM
TreeFarm's Avatar
Here's my SWAG on it.
I believe the system calculates it based on the amount of fuel in the tank and the calculated MPG. They probably use a moving average of the MPG, so that the DTE reading doesn't jump around.
I don't think it is really reset. I imagine it is calculated at some short interval, and when you fill the tank, the next calculation will based on a full tank, instead of whatever level it was when you pulled up to the pump.
Hope that makes sense.
Old Sep 5, 2007 | 09:49 AM
dssimecek's Avatar
Example on our 02 Running around town
Overhead shows ave MPG 11.0
Fuel gage reads 1/4 9 gallons remaining. DTE reads 99 miles
I put 10 gallons of fuel in. Fuel gage reads 1/2 DTE reads 209
On Hwy, ave MPG reading 20 MPG. 1/4 tank remaining, DTE reads 180 miles.
I add 10 gallons of fuel DTE goes up to 380
As I drive the ave MPG changes, as will the DTE reading.
Does that clear it up?
Old Sep 5, 2007 | 03:18 PM
J BODY's Avatar
where's the "clapping hands" smiley when you need it....
....all very good info!
Old Sep 5, 2007 | 06:37 PM
atch's Avatar
Are you saying it averages off of what the fuel guage reads?
Old Sep 5, 2007 | 07:33 PM
TreeFarm's Avatar
Yes, combined with the your computer's idea of what your fuel mileage is. Then it calculates DTE.
Old Sep 5, 2007 | 07:51 PM
atch's Avatar
I am trying to figure out how I can shut off a transfer pump that's going to pull fuel from an auxillary fuel tank
I'm looking for any ideas
Old Sep 6, 2007 | 08:48 AM
dssimecek's Avatar
Not sure what you are doing with the aux tank.
Transfer fuel to the main tank to fill it?
Direct feed to the engine?
How large is the aux tank?
A switch and a shutoff valve would close the feed from the aux tank.
Old Sep 6, 2007 | 09:21 AM
TreeFarm's Avatar
So, what you really would like to know is, "How do I automatically detect when my main tank is full, so that I can shut off a fuel transfer pump?"
Do I have it?
Old Sep 6, 2007 | 11:14 PM
J BODY's Avatar
Do I have it?
http://www.transferflow.com/trax-ll.html
Old Sep 7, 2007 | 06:31 AM
atch's Avatar
Originally Posted by J BODY
Yea, that's what i'm looking for
Thanks, JBODY
Old Sep 7, 2007 | 06:38 AM
TreeFarm's Avatar
I had an auxillary fuel tank installed in a Lotus. Like the system in the link, I never had to worry about fuel transfers, either. My fuel gauge automatically read both tanks, fuel was drawn from both tanks without any manual valve fiddling, and the system never gave me bit of trouble in over 45,000 miles of use.
The "system" was a T fitting.
Old Sep 7, 2007 | 06:44 AM
atch's Avatar
That would be hard to do when the aux tank holds 95 gal. and sitsa foot above the main tank. I would need a way to keep the main from over flowing.
atch
Old Sep 7, 2007 | 07:10 AM
TreeFarm's Avatar
atch
I know. I was kind of making fun of how complicated today's vehicles have become. I doubt there are too many vehicles made today that could use a simple T fitting for any aux tank. Too much plumbing these days, what with return lines, vent lines, vapor capture issues, etc.
Looks like J BODY may have found you what you need. I hope it works well for you and isn't too expensive.
irocpractice
Sep 12, 2008 08:48 AM
BigBlue
Nov 7, 2002 07:14 AM
