Intermitten HIGH Amp draw during idle ????
Old Nov 6, 2006 | 09:56 AM
Katmandu's Avatar
Exclamation Intermitten HIGH Amp draw during idle ????
When my truck is at idle, I've been noticing the Amp gauge drawing down BELOW 14 Volts in a cyclical pattern.
Meaning every (2) minutes or so, it will show a HIGH Amperage draw down (gauge moves left and the lights dim). It will stay in this draw down for about 15-20 seconds or so and then return to normal.
It's acting like heating element is cycling On-Off. There are NO gauge lights coming on and only the AMP gauge shows the suspect activity.
My truck no longer has the Fuel Pre-Heater element. It melted last year and removed it completely a few months ago. I also recently had the alternator, batteries checked out and terminals all cleaned. All checked out just fine.
What is causing this intermitten HIGH Amperage draw on my truck's electrical system ???
Old Nov 6, 2006 | 10:08 AM
darkvader's Avatar
when you first start it ?. does it do it all the time ?,when warmed up ?.
Clark
Old Nov 6, 2006 | 10:09 AM
Mcmopar's Avatar
It sounds like the grid heaters cycling on and off. This happens when it is cold outside and the truck is cold--right??
Old Nov 6, 2006 | 12:42 PM
XLR8R's Avatar
Grid heaters... make sure they only cycle when the air is cold and the engine is at or close to idle at less than ~16mph
Old Nov 6, 2006 | 02:20 PM
John DiMartino's Avatar
grid heaters draw over 200amps,they should cycle until the truck warms up or hits 20 mph once.
Old Nov 6, 2006 | 03:12 PM
bnold's Avatar
I believe he said he took the grid heaters off???
Old Nov 6, 2006 | 03:18 PM
XLR8R's Avatar
He said he took the fuel heater off after it (the connecter, usually) melted.
Old Nov 6, 2006 | 03:20 PM
bnold's Avatar
Oh ok, misread I vote grid heater then!!
Old Nov 6, 2006 | 06:36 PM
infidel's Avatar
If the climate control is in one of the defrost modes the air conditioner will cycle on and off.
Old Nov 9, 2006 | 12:01 AM
timcha's Avatar
My old 99 did the same thing once it hit about 65000miles. It didn't matter what the outdoor temp, how warm the motor, what speed you were traveling, or what was on tv.......never could get the dang thing to stop. It would literally dim the lights it was so bad.......
alramr
87
Jan 31, 2010 06:21 PM
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
USMC64-70
Oct 6, 2003 11:45 AM
