Instructions to Tap manifold
Old Jun 20, 2009 | 08:19 PM
barngal6's Avatar
OK, i have drilled the hole in the manifold for the pyro sensor
I have the 1/8" NPT tap
What is the procedure for tapping the hole successfully?
I have a little grease, and a 3/8" socket fits the top of the tap
How do I make sure I don't wiggle the tap so the threads cross up?
thanks
Old Jun 20, 2009 | 08:48 PM
1-2-3's Avatar
Just a plain ole guy
Lots of oil, shop vac to catch shavings, preferably a tap handle and not a socket and rachet. A socket will give you too much leverage. And most importantly, drill a hole in a scrap metal and try it out there first. A broken tap can be a terrible thing to remove.
Old Jun 20, 2009 | 09:44 PM
benroberts3605's Avatar
key is to go slow. turn about a 1/4 turn and back it off do another 1/4 turn and back it off. dont rush it and get greedy or you will break the tap off in the manifold.
Old Jun 20, 2009 | 09:50 PM
Dr. Evil's Avatar
http://www.spaco.org/begintap.htm
Check this out - http://www.youtube.com/watch?v=p7wd2Lenmlo
Old Jun 21, 2009 | 10:30 AM
barngal6's Avatar
Great links, thanks Dr. Evil. The tap went way easier than I thought. I didn't have a tap handle but I used a small ratcheting wrench very carefully. And oil.
tightening the threaded bolt into the manifold, I snugged it down, then gave it a couple of turns, I stopped before it was completely tight because I worried that as soft as the manifold was, I'd strip something. So part of it still sticks up but I've ready that that's ok.
I have a guage question that I'll post under my other thread about the pyro sensors--if I install the sensor but don't hook up the wires yet, do I need to keep the two wires separated? So that they don't touch? And a little more on that subject. Anyways I really appreciate the "walk through" to do the tap.
Old Jun 21, 2009 | 10:32 AM
Onemoparnut's Avatar
No It wont hurt if the wires touch as long as there is no power hooked to either one.
Old Jun 21, 2009 | 10:49 AM
barngal6's Avatar
Gotcha -- thanks.
So once there's power guess I need to use a heat sleeve on each wire to keep them separate..I received 2 heat sleeves with my kit, I can cut each in half for the connections on either end of the blue wire connecting the guage end to the sensor end
Should I just zip tie the heat sleeves? They are fabric, they don't look like the regular shrink tubing
PLEASE DON'T REPLY HERE! This discussion moved to my thread
Help w/gauge install, might be helpful to someone else someday
https://www.dieseltruckresource.com/...=1#post2509343
thanks again for all of your help with the tap!
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
alto22
34
Feb 16, 2007 09:28 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
