Installed FASS - won't start!
Old Jan 15, 2006 | 03:51 PM
Rauschbo's Avatar
....got it all installed, and can hear the pump run when I turn the key on; Cycled it several times, and - the engine cranked, but would not start! Ran the batteries down by cranking it in about 5-10 second intervals. The pump runs after the key is off....is that normal?
So....you guys know where I start my troubleshooting?
Thx -
Rauschbo
Old Jan 15, 2006 | 03:56 PM
rockwithjason's Avatar
Did you crack the lines at the injectors and bleed the fuel system? If you did and you got fuel at the injectors then I would look at a restriction somewhere in the system. Perhaps you are sucking in air from somewhere?
Old Jan 15, 2006 | 05:11 PM
RickCJ's Avatar
He didn't say he bleed the fuel system! I can't imagime a DTR pres. that wouldn't do that 1st.
Old Jan 15, 2006 | 05:40 PM
Rauschbo's Avatar
....yep, that was to be the first step ....HAD I not drained the batteries! I'll try to charge them, but...they're pretty dead, and pretty cheap, I may have to put new ones in before I can finish this project up....
I may pull the line off the IP to make sure there is a full load there before I start cracking injectors.
Old Jan 21, 2006 | 04:26 PM
Rauschbo's Avatar
....Update:
Yanked the POS QD from the tank, and clamped the hose - (after installing new batteries!), the pump IMMEDIATELY sounded way different. Had to prime it to the VP, and bleed 3 injectors to get it to fire, but fire she did, and I'm back on the road!
Now, when is Quadzilla going to release the latest version of their chip....??
Old Jan 21, 2006 | 04:35 PM
P.J's Avatar
P.J
Where's Superduty at when you need him?
He'll tell what to do with that aftermarket fuel delivery system.
Just kidding,......... take it easy fellas!
Old Jan 21, 2006 | 06:08 PM
J BODY's Avatar
Originally Posted by Rauschbo
....Update:
What does this mean????
Old Jan 21, 2006 | 07:35 PM
Bad Ramer Jamer's Avatar
I think that mean's one of two thing's. Either he didn't have the dis-connect on the tank connected very good, or he fixed it by bleeding it the other way.
Old Jan 21, 2006 | 07:37 PM
Geico266's Avatar
It means the POS (piece of poop) QD (quick disconnect) was leaking air and he took it off and used a hose clamp.
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
Louis
Jul 14, 2006 07:08 PM
