Installed engine, turn key, NO FUEL PUMP
Old Jul 25, 2008 | 10:27 PM
Checkmate's Avatar
MORE !!!Installed engine, turn key, NO FUEL PUMP, OR COMPUTER
I rebuilt the engine and just got done hooking everything up. I get in, turn the key to "ON" and nothing. I can hear a small click out of the fuse box, but no fuel pump like normal. My fuel pump is still mounted on the fuel filter. Crank and crank and nothin happens, but at least I primed the oil system. hahaha.
Anyway besides assuming the pump went bad from sitting for 3 months, what should I look for ? The plugs are all plugged in as far as I can see. I even unplugged and replugged the fuel pump. I will throw the tester on the wires tomorrow, just hope something is not wrong with the computer.
Old Jul 25, 2008 | 10:56 PM
dozer12216's Avatar
check fuses and relays. You have left something loose!!!!
Old Jul 26, 2008 | 06:17 AM
Checkmate's Avatar
hahaha hope your right. :-)
Old Jul 26, 2008 | 02:55 PM
Checkmate's Avatar
UPDATE !!!
Hooked up a test light today and am getting a ground out of one line to the pump, but NO Power at any time.
Also, check engine light is on. I tried to pull the codes and got a "NO LINK" message. What the heck . plugs and grounds look all good ?????????????????????????????????????????????????
Also. No voltage or fuel guage reading.
Old Jul 26, 2008 | 04:08 PM
dozer12216's Avatar
Have you hooked up all connectors without damage? See if have bent terminals or corroded pins. Check all fuses, including large fuse for alternator if present. Follow alt lead into fuse block.
Old Jul 26, 2008 | 05:23 PM
Checkmate's Avatar
I didn't have any problems with the connectors and they were all clean. I will check them all out again though . IS there only one power wire to the computer ??
I will also go through all of the fuses and check them although none looked bad from a glance.
Pullin my hair out here.
Old Jul 26, 2008 | 09:46 PM
Checkmate's Avatar
GOT IT. :-) It was one of the plugs on the bellhousing.
After letting the LP prime itself, she fired right up and is quieter than ever.
Old Jul 27, 2008 | 07:40 PM
dozer12216's Avatar
Attaboy!!! Knew if kept looking you'd find issue.
Old Jul 27, 2008 | 10:16 PM
Checkmate's Avatar
I always has to be somethin stupid simple.
keithb7
Nov 30, 2008 07:25 AM
EverydayDiesel
Dec 1, 2007 07:01 PM
stealman1
Nov 9, 2007 11:07 AM
rkelley
Oct 20, 2006 05:55 AM
big red psd cc
Dec 29, 2004 11:38 PM
