Injector Pump Leak
Old Jan 22, 2003 | 08:25 AM
Bo's Avatar
Bo
Injector Pump Leak
I searched the archives but could not find any info on this.<br><br>1992 Cummins, When the engine is running fuel drips<br>out of the top of the injector pump. Looks like it <br>is coming from under the throttle linkage. Is there <br>an o-ring on the shaft, can this be snugged up. <br><br>Thanks for any advise.<br><br>Bo
Old Jan 22, 2003 | 01:48 PM
RCW's Avatar
RCW
Re:Injector Pump Leak
Bo,<br><br>There is a seal kit for the VE pump, and it is dirt cheap. Here is one supplier: http://www.fuelinjectionpumps.com/ve.html
Old Jan 23, 2003 | 02:08 AM
Bushy's Avatar
Patron Saint of 1st gens
You need to be careful if you're going to do the repair yourself. <br>The throttle shaft is indexed and MUST be re-installed in the proper location or you will not have proper throttle travel. It's a ratty job with the pump on the truck.<br><br>Bob.
chevummins
Sep 30, 2004 03:37 AM
ramlovingvet
Jun 24, 2004 09:26 AM
Bluebird
Jan 6, 2004 12:44 AM
