inj pump rebuilt, bad mileage
Old Jul 16, 2007 | 05:53 AM
renacolt's Avatar
I was wonering if anyone has ideas on this problem. I have a 95 w/12 valve, had the injector pump rebuilt. It had the TST fuel plate on it and now since the rebuild I am getting about 1/2 the mileage when pulling. I am wondering if they maybe didn't put the plate back or if something else could cause this problem.
Old Jul 16, 2007 | 07:09 AM
patdaly's Avatar
Lets start with a few Q's
1.) Why was the P7100 rebuilt?
2.) Did they check the timing prior to pulling it, and is the timing the same as before?
3.) Clarify the MPG's, for instance it used to be 14 towing, 20 not, now its 7 towing, 18 not, etc.
4.) fill us in a bit more on your combination, tranny, gears, etc.
Once you have done those, I think you will be astounded at the sheer level of knowledge floating around the nooks and crannies here.
ClassA4x4
Aug 2, 2011 06:51 PM
rockmike
Apr 21, 2011 09:47 AM
9 sec camaro
20
Aug 26, 2006 01:30 PM
bdog
Dec 2, 2002 07:32 PM
