Hit a pot hole pretty hard and truck died
Old Jun 23, 2007 | 04:17 PM
JD farmboy's Avatar
Exclamation Hit a pot hole pretty hard and truck died
A guy I work with just called me and said his grandpa hit a pothole on his 2000 CTD and the engine just died like you turned off the key. The only code that he is getting is the P1693 code and thats it. Anybody have this problem before? Anybody got any idea's? The truck will NOT restart, he cracked open an injector line and he is getting no fuel.
Old Jun 23, 2007 | 04:44 PM
7.3's Avatar
7.3
I am not familiar with the Dodge, but on any other vehicle I would check the emergency cut off switch.
Old Jun 23, 2007 | 04:59 PM
vzdude's Avatar
DTR's 'Go to Guy'
No switch like that on the Dodge. That seems to be a Ford thing.
Old Jun 23, 2007 | 05:43 PM
John Faughn's Avatar
I do not know if they stopped , but dodge has had since the beginning of computers has had an auto shut down relay , turn power off to computer fuel pump ect gas & diesel .
That said , I would lean towards a fuse , fusible link , battery connections .
Does the starter engage , I would guess so , since you said no fuel , but the no fuel should give you a place to start looking , electrical getting to pump ?
Old Jun 24, 2007 | 09:32 AM
JD farmboy's Avatar
Ok, after more checking, he said he is actually getting fuel to 45&6 but not 12&3, however, it is interesting that he has no codes on the ECM, I wonder if he has lost power to the ECM somehow......? Anybody know how the ECM gets its power?
Old Jun 24, 2007 | 11:36 AM
blackdiesel's Avatar
Registered
A guy called me once. He was tring to teach his girl how to drive a stick. She dumped the clutch in 3rd and it bucked real big and died. I told him how to check for codes and all he got was the 1693 also. I took my smarty over there and got a 1688, SSOOO, I got him a new VP44, and put it on and he blamed it all on his poor little girl.
Old Jun 24, 2007 | 11:37 AM
Registered
P.S. there is another code in there, I would find it before I went to alot more trouble.
Old Jun 24, 2007 | 11:42 AM
Its call the auto shut down relay .
Old Jun 24, 2007 | 11:49 AM
Registered
If the ECM didn't have power the LP wouldn't run, and you wouldn't have any fuel. Try a scanner on it, alot of times the key won't pull all codes.
Old Jun 24, 2007 | 01:43 PM
EverydayDiesel's Avatar
how much is a smarty?
Old Jun 24, 2007 | 02:52 PM
Registered
Get aholed of Bob wagner on here. I'm not pricing them for him, but around 650
Old Jul 5, 2007 | 07:36 PM
7.3's Avatar
7.3
Did he get the truck running?
Old Jul 6, 2007 | 10:53 PM
XLR8R's Avatar
What happened?
Trooperthorn
Jun 9, 2014 10:53 PM
01DODGESMOKER
Feb 25, 2009 02:09 PM
DodgeCTD
22
Jun 21, 2008 09:39 AM
Billm2004
38
May 15, 2008 06:24 PM
Dave88LX
Jul 20, 2006 11:22 AM
