igniton switch/ relay help
Old Jan 9, 2007 | 12:12 PM
corkinu93's Avatar
i was driving my truck last nite and could smell plastic melting....a few seconds later the water in fuel lite and wait to start lite came on while the truck was running. I made it home and strated searching for the problem,i cycled through the ignition a few times and smoke came out,then truck wouldn't do anything.Took the bad ignition switch out today,replaced it with a new one and it still won't start.I have power door locks and the blower motor will come on but no wait to start lite and will not crank,i have checked rthe fuses but i really don't know where else to look.....please help....thanx
Old Jan 9, 2007 | 12:19 PM
John Faughn's Avatar
You should go to the user control pannel and fill in the truck info , to get answers .
Do you have a test light , check circuts for loss of power , did you check both fuse / relay locations , very from truck to truck yr/mdl , follow hot wire from ing. sw. to fuse / relay .
Look under hood at starter wires , if a 12v , some times the starter solinoid will spot weld inside and burn up fuel cut off , again truck info .
Chrisreyn's Avatar
Check the fusible links on the drivers side fender wall..
Old Jan 9, 2007 | 12:44 PM
corkinu93's Avatar
Truck Is A 93 Ctd,auto 4x4 By The Way
Old Jan 9, 2007 | 12:52 PM
corkinu93's Avatar
What Does The Fusible Links Look Like
Old Jan 9, 2007 | 01:52 PM
Do not remember the last time I looked at the 93 , lots of changes in 94 , but there should 1 at least maybe 2 , on the drivers side , medium wires , about 8 gage wire , they are made of an aloy that melts easy , so that they act like a fuse [ fuseable link ] about 4-6 inches long , if you give a light tug on them they should be solid , no give , if there is a little stretch then the is a break / burn . use a meter bat. grd . then the sharp probe to poke through the insulation to look for power also .
Old Jan 9, 2007 | 02:05 PM
corkinu93's Avatar
I Have Checked All The Fuses In The Fuse Block And They Are Good...i Have Over 12 Volts Coming Out Of The Ignition Switch,but It Drops Down To 0 When You Hold It To Start,none Of The Accesories Inside Work Except Bower Motor
Old Jan 9, 2007 | 02:14 PM
corkinu93's Avatar
I Cannot Find The Fusible Links You Are Talking About.....there Are 3 Relays On The Drivers Side Inner Fender And There Are Two Blocks Bolted To The Wheel House That Has 4 Wires On Each One....2 Large Wires And 2 Small Wires Are These It?
Old Jan 10, 2007 | 05:11 AM
corkinu93's Avatar
Also There Are 3 Relays Bolted To The Left Inner Fender,are One Of These A Starter Relay? The One Towards The Front Of The Truck And The One Toward The Fire Wall Are The Same....the Middle One Is Different
Old Jan 10, 2007 | 07:49 AM
Chrisreyn's Avatar
Cork, there was thread recently that had photos of the different relays and what they are.. cant remember the name of it though. try searching the forums and you may find it.
OK, I found it.. hope this helps :https://www.dieseltruckresource.com/...light=identify
Old Jan 10, 2007 | 10:19 AM
The fuseable links come off the + batt. term. , the wire that loses power in the start pos. , are you sure that is the wire to stater ? The acc. wire , is loses its power in start pos. so that all the power goes to starter , so if your on the acc wire when the power goes away , thats as it should be . but not the start wire , if it is the start wire thats loseing power , than you found your problum .
Remember the start circut and the acc are two different circuts .
Old Jan 10, 2007 | 11:43 AM
dpuckett's Avatar
The fusible links are right next to the relays on the driver's fender. They split into 4 wires coming off a rubber splitter doo-hickie. One line going in, 4 coming out the other side, downstream from the battery. They can look good and still not do anything. You will need a test meter, I believe. Sorry I cant be more help.
Daniel
Old Jan 10, 2007 | 06:03 PM
corkinu93's Avatar
okay...i found the fusible links....i am thinking one might be bad...not quite sure yet......as far as the starter relay,i looked at the pictures on the link and it is different that the one i have,all 3 relays i have are the black plastic style. This thing is so aggravating.John you were correct about the power and acc. wire....thank you for your help with that part. If one of the fusible links is bad would that cause the wait to start light,water in fuel light,radio and starter not to work?
Old Jan 10, 2007 | 06:38 PM
Yes, it would.
The rear relay on yours is the starter relay. You can swap relays around to test it.
Old Jan 10, 2007 | 07:00 PM
corkinu93's Avatar
okay....thanks for the info......i will try that....hopefully it works!
