Ignition switch issues on my 94
Old Feb 29, 2008 | 11:23 AM
heykw's Avatar
Ignition switch is not working and truck will not start it seems like the problem is in the ignition switch it does not spring back when you let go of it after it has been in the start location any input would be appreciated thanks
Old Feb 29, 2008 | 12:05 PM
infidel's Avatar
New key switch for a '94 is about $30 at Napa.
You don't have to change the key portion of the switch but will need a security torx bit to remove it.
Old Feb 29, 2008 | 12:21 PM
heykw's Avatar
I don’t think it is the switch because the switch part does not have the spring in it? When you turn the key to the start location it does not spring back?
Old Feb 29, 2008 | 12:44 PM
kthiemann's Avatar
the ignition switch is 2 pieces, there is the key cylinder and the electrical portion, more than likely the problem with yours is in the electrical portion, it's a pretty easy fix, just a handful of screws.
OldDodgeOwner
Oct 31, 2010 05:47 PM
heykw
Feb 29, 2008 12:31 PM
heykw
Feb 29, 2008 12:29 PM
GaCamper
Dec 1, 2003 08:59 PM
D4Fritz
Mar 16, 2003 03:55 PM
