Problems after PCM replacement
Old Feb 25, 2008 | 08:57 AM
ShortyTigg's Avatar
Last Monday my Dodge dealer replaced the PCM due to an "internal fault." (The alternator gauge had suddenly dropped to the left while I was driving.)
I picked up the supposedly repaired truck ($850), but when I started it up, the fasten seat belt light stayed on. When I drove off, the ABS and brake indicator lights came on. So I left the truck for the dealer to check it out.
Four shop-days later, it still has the same symptoms. I've been searching the internet to find similar problems so I can talk intelligently with the shop. I keep coming up with "program the VIN" -- is there any way they could have messed this up, or is that too obvious? Also, can anyone explain "set pinion factor in ABS module" ? -- Google hit that one as a possible reason for the ABS light to come on after a PCM replacement.
Thanks in advance,
Shorty
1998 Dodge RAM 24V diesel 4x4 66,000 miles
new batteries Nov'07
new alternator Dec'07
Old Feb 29, 2008 | 08:58 PM
dozer12216's Avatar
Both are valid info to plug into new controller.Should have been auto part of repair. Pinion factor is adjsutment for # of teeth on ring gear. Vin will complete program parameteres for particlar engine married to.
c-bass
Jun 19, 2010 08:18 PM
Virginia Diesel
14
Sep 16, 2008 06:59 PM
Big Perm
Dec 18, 2007 08:44 PM
Lark
Feb 27, 2007 05:32 PM
sjester
Feb 11, 2007 11:15 AM
