Idles to high
Old Jun 8, 2007 | 10:15 AM
GNGMarc's Avatar
Idles to high
I've just converted from GM6.5TD's to the cummins!! I just bought my 1997 Dodge 3500 Dually 183K, basically stock with a HX35 turbo, and a 47RE auto trans. The idle seemed a little high, but the truck ran awesome. Preventively I took it to a friend who owns a Mopar tranny shop and he suggested replacing the govenor solenoid switch and transducer, so I did. When I got it back yesterday, the idle was even higher...750-800 in gear, 950 in park or nuetral. I looked at the accelerator cable to pump linkage and everything looks great, no binding. I see where the cable end pulls on and rotates on the shaft on the side of the injection pump, but the idle adjustment is not straight forward. I was expecting to see an idle adjustment that I could move, but I can't seem to find it, need help, Thanks
Old Jun 8, 2007 | 10:45 AM
b.lee's Avatar
there is an idle adjustment on the back of the P7100.
www.cumminsdatabase.com will have all the pics and answers you need
Old Jun 8, 2007 | 10:54 AM
winkle's Avatar
There's a 10mm bolt with a lock nut on the back of the injection pump that a lever hits if you screw it in it will lower the idle. If the idle at 750-800 that about right it should be.
Old Jun 8, 2007 | 11:45 AM
GNGMarc's Avatar
Thanks a million!!!
Old Jun 9, 2007 | 05:05 PM
fschiola's Avatar
Remember, you're setting the idle in gear with the A/C on.
Old Jun 10, 2007 | 03:52 AM
EverydayDiesel's Avatar
welcome to the site
750 is where mine idles at in and out of gear.
Old Jun 10, 2007 | 08:01 AM
fschiola's Avatar
That's because the computer controls the idle speed on your truck. It's not adjustable.
stealman1
Apr 12, 2009 11:45 PM
CTD2001
Feb 8, 2008 07:56 PM
CARR
33
Dec 9, 2006 09:57 AM
qcstunter
Feb 28, 2006 10:16 AM
