12 valve idles too high
Old Feb 24, 2006 | 06:19 PM
qcstunter's Avatar
I have a 98 12v and the truck idles at 1100 rpm. What would make it idle high and what is it supposed to idle at?
Old Feb 24, 2006 | 06:39 PM
infidel's Avatar
Click this http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old Feb 24, 2006 | 08:07 PM
qcstunter's Avatar
I loosened the locknut and theaded all the way in and it did not change the Idle at all.
Old Feb 24, 2006 | 09:36 PM
moonpie's Avatar
I too have this problem. I can force the linkage down, but it comes right back up. Mine is stuck at ~900. Liveable , but still confusing. Maybe I have a sticking linkage somewhere.
Old Feb 24, 2006 | 10:16 PM
nick17847's Avatar
Do this with the engine running and in Park. With your right arm burried in there at the adjustment screw, ..use your left arm and reach for the throttle rod/lever that goes between the back of pump and TPS, ..rev the engine a little to take the trension off of the adjusting screw (obviously after you've loostened the 10mm locknut). 900 when out of gear is about what you want. But, check it in gear with AC on, ..shoot for 750, but 800 is better.
Old Feb 24, 2006 | 10:21 PM
dieselhawg's Avatar
your linkage may be binding or not adjusted right,make sure the return springs are pulling the throttle closed.
Old Feb 25, 2006 | 09:57 AM
infidel's Avatar
Fairly common for the throttle return spring(s) end to break off, they can then fall off and be totally gone.
Spring from the hardware store is an easy fix.
Old Feb 25, 2006 | 05:57 PM
Sidewinder's Avatar
Sometimes the throttle cable gets frayed and the wires sticking out hold it open. There was even a recall on this. Check the cable!!
Old Feb 25, 2006 | 11:13 PM
plow's Avatar
there is an another adjustment right above the idle adjustment that has 4 or 5 holes in it, its connected to the throttle linkage and if not adjusted right will not allow full movment of the linkage.
Old Feb 28, 2006 | 02:30 AM
qcstunter's Avatar
thanks for everyones help. I will check the linkage while its running tommorow I think there is something wrong with my cables because when you press the pedal, its easy till about 80% throttle, then you have to press harder for wide open throttle.
Old Feb 28, 2006 | 07:25 AM
Dr. Evil's Avatar
I believe there was a recall on the cable....(I need to check my truck too).
Old Feb 28, 2006 | 10:11 AM
infidel's Avatar
Sounds normal if the engine isn't running.
Start it and my bet is it will become easy.
Old Feb 28, 2006 | 10:16 AM
Baja's Avatar
The throttle recall is #970. That is the code the dealer will look under. Call your dealer with your VIN# and they will be able to tell you if the work has been done or not. It made a difference for me, my cable was really frayed.
stealman1
Apr 12, 2009 11:45 PM
CowRazy
Aug 26, 2007 10:00 AM
GNGMarc
Jun 10, 2007 08:01 AM
the.hogman
Jan 4, 2007 07:50 PM
CARR
33
Dec 9, 2006 09:57 AM
