I ran out of diesel today...
Old Oct 12, 2005 | 07:19 PM
Rob Ez's Avatar
just a few hrs ago. Put several gallons back in the tank - opened and filled filter housing but truck still won't start...
suggestions ?? Thanks in advance - Rob
2500 2001 Dodge Cummins TD quad cab
Old Oct 12, 2005 | 07:36 PM
mikmaze's Avatar
loosen fuel cap and turn key to run, not start and repeat till you see fuel sputter out, wait a few seconds between cycling the key and listen fo rthe lp to run. once it spits fuel tighten the filter and then start
Old Oct 12, 2005 | 07:40 PM
Rob Ez's Avatar
I'll give that a try - THANKS
Thanks for the input...
Old Oct 12, 2005 | 07:41 PM
crobtex's Avatar
You might need to crack injectors one and three. That will help prime the injector pump.
Old Oct 12, 2005 | 08:52 PM
Rob Ez's Avatar
more info
what does DTC (Diagnostic Trouble Code) P0460 mean ??
Old Oct 12, 2005 | 08:54 PM
phox_mulder's Avatar
In the 2nd gens, it meant "Fuel Level Unit No Change Over Miles",
bad sender in the fuel tank.
phox
Old Oct 12, 2005 | 08:57 PM
hotdram's Avatar
Click here for a list of trouble codes
And welcome aboard Rob
(the above link is from the Tech Facts section at the top of the page )
EDIT: I just noticed that the 0460 code is not listed there.
~Rob
Old Oct 12, 2005 | 09:16 PM
STATELINE's Avatar
P0460 - Fuel Level Sensor Circuit as per here ; http://www.autotap.com/generic_trouble_codes.html
think it means you ran it out of fuel, seems you already knew that.
Old Oct 12, 2005 | 09:18 PM
Originally Posted by hotdram
He has a 2001, I believe the 2003's and up are common rail.
~Rob
Duhhh
I could've sworn he had 2005 in his sig.
phox
Old Oct 12, 2005 | 09:23 PM
crobtex's Avatar
"2500 2001 Dodge Cummins TD quad cab"
Well, it is close.
Old Oct 13, 2005 | 05:14 AM
Rob Ez's Avatar
thanks
Thanks for all the help - bled all the air out at the banjo bolt and at the injectors too - cracked 5 of 6. After about 5 mins, and lots of air escaping - it started with no problem. I IMMEDIATELY went to top off the tanks- I won't be doing that again (running out) EVER !!!
Old Oct 13, 2005 | 05:40 AM
crobtex's Avatar
Glad you gotter done.
Old Oct 13, 2005 | 06:03 AM
jrs_dodge_diesel's Avatar
Excellent. A note for anybody reading this. You only need to crack 3 injector lines. The engine will start and run on three cylinders. Once its running the others purge fairly quickly.
Jer-ah
Dec 1, 2013 11:45 AM
Deadbunny
Mar 29, 2009 10:17 PM
txsdodge2001
Dec 8, 2007 01:50 PM
zero2zero
Apr 13, 2007 10:30 PM
