I have to leave tomorrow A.M.!!!
Old Aug 28, 2009 | 08:18 PM
Plumb Wild's Avatar
I just got done washing my truck to leave for terre haute tomorrow morning at 5 a.m. As soon as I started to truck I noticed the tranny light was on. I ran the key cycle and saw that the p 1693 code came up. I looked around on here and see that this is a companion code and i need to get it cleared at an auto zone, etc. My question is should i trust my truck to make the 3 hour trip before it can get looked at????
Old Aug 28, 2009 | 08:34 PM
mishkaya's Avatar
Did you wash in the engine compartment per chance? If so I would not worry about it as it is most likely just some moisture in the wiring. If your truck seems to be running OK, I wouldn't worry about the P1693, it can pop up for many reasons. Good luck!
Old Aug 28, 2009 | 08:36 PM
Plumb Wild's Avatar
meant check engine light
Old Aug 28, 2009 | 09:03 PM
st.rodder2's Avatar
Sounds like you may have gotten a connector wet. Here is what I found for the P1693 Code: Turbo Charge Control Circuit Malfunction. If it's running fine I wouldn't worry about it. Take it for a good ride tonight to take and dry it out.
Old Aug 30, 2009 | 03:12 PM
Plumb Wild's Avatar
Thanks for all the help guys. Just got back without a bit of trouble and the light even went off.
Txwelder
Mar 27, 2007 05:14 PM
johnadkins
Sep 17, 2005 08:36 AM
Diesel diehard
Feb 10, 2004 08:25 PM
mountainman
Apr 8, 2003 09:49 PM
