How in the heck do I disconnect..........
Old Apr 22, 2005 | 04:28 PM
NO1B4ME's Avatar
Exclamation How in the heck do I disconnect..........
Hey Yah'll,
Got Me fuel tank down from the straps, got everything dissconnected but how in the name of GOD do Yah disconnect the fuel sender electrics. Pulled up the tab, pushed over the red retainer, I cannot disconnect this connection. I'm about to lose it.
97 3500 12V 1ton.
HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEELP
Old Apr 22, 2005 | 05:43 PM
hotdram's Avatar
I looked in the Dodge service manual for '97s and it doesn't specifically say how to remove the connector.
Sorry,
~Rob
Old Apr 22, 2005 | 08:03 PM
RCW's Avatar
RCW
There are two common connectors used in 97, the most common has two compression latches (one on each side, and you compress them and pull the plug toward the side of the vehicle), the other has a single latch on the top, again you release the plastic dog and pull the connector to the driver's side of the vehicle.
Old Apr 22, 2005 | 09:30 PM
NO1B4ME's Avatar
I've pulled and pulled...................
Hey Yah'll,
I've lifted the tab, actually broke it now, slide the red retainer(keeper) to the side, now the red retainer is sittin on My bench, but the connector is still together. I'm about to cut the wire harness, I'm a little loose but not stupid, I have no idea how this thing comes apart. Any help would be appreciated.
THANX
Old Apr 23, 2005 | 05:21 AM
duner's Avatar
after the red tab part there should be a button type of latch, the red tab locks the button in place. good luck
Old Apr 23, 2005 | 02:19 PM
timeagain's Avatar
I have the plug on my AC, I ended up braking the plug to get it apart
Old Apr 24, 2005 | 08:17 AM
NO1B4ME's Avatar
Well its done.............
I ended up gittin that plug apart and completed My new sender and fuel lines. That connection is the worst thing I've ever seen in terms of maintenance but rest assured it would never come apart on its own. Thanx to all for Your input.
NO1B4ME
Old Apr 24, 2005 | 08:48 AM
infidel's Avatar
As you work on your truck you will find quite a few componets that are "quick connected". It means just that, they are quick to connect but a bear to disconnect.
ouchman
Apr 5, 2004 11:17 AM
BigBlue
Nov 11, 2003 11:58 AM
MY_HUMMIN_CUMMINS
Oct 7, 2003 07:08 PM
Dieselhead
Apr 25, 2003 11:38 PM
apc
Dec 11, 2002 11:15 AM
