transmission quick disconnect fittings
Old Dec 11, 2002 | 09:19 AM
apc's Avatar
apc
Ok this was on wifes jeep but my ram has same fittings. What is the procedure for removing them? I have the fuel injection , a.c. quick removal tools but wont work. Looks like some one else had same problem one end of hose all cut up and gnawed off. Changed radiator and just ended up putting on high quality rubber hose and installed barbed ends. So to make a long question short , when i finnaly get the tranny line for my Ram with the port for a temp sender I need to know how to remove with out causing damage.
Old Dec 11, 2002 | 10:55 AM
Smokee's Avatar
Re:transmission quick disconnect fittings
On the '94, you need to pull a hairpin clip out to remove the fitting. The gasline fittings are a bit trickier, and if memory serves, the fittings are different in different locations.<br>george
Old Dec 11, 2002 | 11:15 AM
Mr. 45's Avatar
umm, Can you say that again?
jogl
Jun 16, 2008 05:27 PM
rjm022
Dec 31, 2006 06:00 PM
Neal Cassady
Nov 19, 2005 02:33 PM
Kevins
Mar 28, 2005 11:30 PM
BigBlue
Nov 11, 2003 11:58 AM
