hood won't open
Old Nov 23, 2007 | 04:48 PM
bill moore's Avatar
hood won't open
pulled the lever, cable moved but hood did not open. I disconnected the cable from the lever assembly and tried pulling it and the cable would not move.(cable not broken) I tried banging on the hood. I have to go away for the weekend but need to boost my moms car first and figure out why my grid heater is not working so I don't get stranded. thanks
Old Nov 24, 2007 | 03:54 PM
scootertrash35's Avatar
drive down a rough road while pulling it
Old Nov 24, 2007 | 04:15 PM
dj_souvlaki's Avatar
maybe frozen?
get some silcone spray and lube it good when you get it open.
Old Nov 25, 2007 | 01:08 AM
Mikey G's Avatar
If it's below freezing try leaving it idle for a while out of the wind, and try the latch again. The engine heat will thaw it out if it's frozen. Worked for me once before.
Old Nov 26, 2007 | 06:40 PM
bill moore's Avatar
It is not frozen drove it for twenty hours plowing with the cable stuck outand it did not come up. Also had it in heated shop for five hours. I think that I am going to brake a web in the grill and undo the 6mm bolts holding the bottom latch
Old Nov 26, 2007 | 07:34 PM
Free89W350's Avatar
Before you break your grill try to get up from under the bumper to the hood mechanism. You might need a long strait pry bar to pry the latch mechanism back a little bit. I had to do this to my wifes aunt's truck and we found that the cable was frozen at the latch itself. Just so you know it's tight but you can get in there.
Old Nov 26, 2007 | 08:07 PM
bill moore's Avatar
I will definetly try it
Old Nov 27, 2007 | 11:56 AM
bill moore's Avatar
got it open!!! plastic bit on the end of the cable that holds it in the latch hole broke thanks
Old Nov 27, 2007 | 02:32 PM
Free89W350's Avatar
Good. How did you get to it just out of curiosity, were you able to get it from underneath or not.
Ryan
Old Nov 27, 2007 | 03:17 PM
offroadjosh1's Avatar
glad ya didn't have to break your grill!
Old Nov 27, 2007 | 05:27 PM
bill moore's Avatar
put all the extensions I had together and undid the two 6mm bolts that hold the latch to the hood from the bottom between the tranny cooler and the bumper. I had just taken the plastic off the bottom of the bumper to install a plow which probly helped. Way better than hacking the grill apart. I can be such a butcher when I am in a hurry
Dougk
Jan 30, 2010 12:11 PM
mullishacrew
Jun 21, 2008 07:33 PM
wrangler04
Jul 17, 2007 07:44 PM
Desert Diesel
Mar 18, 2007 08:53 PM
mhuppertz
Oct 29, 2006 07:49 PM
