Helpppp
Old Feb 25, 2006 | 10:32 AM
The_Mudhog's Avatar
P0341 Code Running Bad
I have a 2004.5 Dodge Ram 3500 24V H.O. Edge EZD1000C, KandN FIPK, And A new 5" Magnaflow Turbo-Back.
I took my truck to the dealer for a check engine light. It was the Batterary Temp Sensor.... Truck ran like crap... Sputtering and stalling..... They replaced the sensor and truck ran good for three days then started sputtering and stalling again.... Took it back and they couldn't figure out what was going on with it...... The made the computer trip a code by beating up the truck.... Come up with a P0314 Camshaft Position Sensor Circuit Range/Performance..... They Replaced the Camshaft Position Sensor....
Two days and Sputtering and stallling started again.... Code came on again
P0314 Camshaft Position Sensor Circuit Range/Performance....Now its going to snow in an hour and I have NO Truck...... Somebody Help!!!!!
Gary
Old Feb 25, 2006 | 11:09 AM
oestreich84's Avatar
Sounds like you may have the shorted wire problem too.
Check this thread---> https://www.dieseltruckresource.com/...ght=wire+short
Let us know what the problem was if you find it.
Old Feb 25, 2006 | 11:44 AM
The_Mudhog's Avatar
I found that wire but it doen't look like it's freyed.....
Old Feb 25, 2006 | 01:19 PM
The_Mudhog's Avatar
I took off all the factory tape and retaped all three wires seperatly.... Seems to be running fine so far..... Still have P0341 Camshaft sensor code.....
Thanks for all your help.... Will be going to the dealer on Monday... I hope it doesn't die on me during this snow storm..... I hope that this is the problem...
If not I'm scr#wed....
Old Feb 25, 2006 | 04:48 PM
The_Mudhog's Avatar
What ever I did... Check engine Light went off and truck runs awsome.... Thanks OESTREICH84 Your the best....
Old Feb 25, 2006 | 05:32 PM
Glad to help out another member! It's funny how such a small wiring problem can cause so many issues
Old Feb 26, 2006 | 03:49 AM
Rauschbo's Avatar
....my CEL has come on and gone off 3 times in the last 4 months - the tach quits working, and the ammeter shows that it is not charging the batteries, got the CKP code; This has lasted briefly in each event. Not sure if I have an intermittent connection, or a bad CKP - I have a new CKP sitting on the back seat JUST IN CASE -
Note: $45 at a Cummins dealer, almost $80 at a Dodge dealership....
Old Jun 8, 2006 | 07:59 AM
The_Mudhog's Avatar
Truck is running bad again. I took the tape off the A/C High Press. switch again and re-taped it. Problem still there..... Is there any other spot you can think of that it might be causing the P0341 Code to come up again. Also, Got code P0148 Fuel Delivery Error. I think that is Quadzilla Chip Related. Any Help would be great.
Gary
arcticcat12224
Dec 18, 2012 10:20 AM
mainer
Aug 1, 2007 10:57 PM
FORDNOMORE
Feb 10, 2004 05:34 PM
