Help!! Truck wont start after changing Fuel Filter
Old May 26, 2006 | 11:50 AM
Ddge6spdRam's Avatar
Well I changed the fuel filter,oil filter and oil today since my dad is pulling out to night to deliver the truck to PA.
Once I got everything buttoned up,I jumped in the truck to start it and it started up, so I jumped out to check for leaks and it started sputtering and then it shut off. I got back in and shut the key off and then back on and waited for all the lights to go out and then try starting it again all it did was crank over. Does the system need to be reprimed after changing the fuel filter or what?
I checked the codes and all it thru at me was P1693, Does anyone now what this means?
This truck has to be ready to go by 6:30pm tonight or we are keeping it..
Jeff
Old May 26, 2006 | 11:53 AM
MADMATT's Avatar
no expert here by no means but sounds like a weak lift pump. what u could do wha ti have seen done is take a tennis ball and put a hole in either side of it so u can use a air hose to pressure up ur fuel tank. buddy did that and it worked.
Old May 26, 2006 | 11:58 AM
Is there anyway to test the lift pump? We really don't what to drop the truck off and have it die on the guy a week later or it dies on the way down to PA.
Thanks
Jeff
Old May 26, 2006 | 12:04 PM
MADMATT's Avatar
fuel pressure gauge u can try or when u go to click the key to start do u hear the pump kind of click? you should hear that pump when u turn ur key
Old May 26, 2006 | 12:07 PM
Well their is no fuel pressure guage, I will go ut now and see if I hear the pump running. Last tuime I tired starting it I was on the phone with my dad and the truck was beeping... So I will go out now and try...
Old May 26, 2006 | 12:08 PM
MBman's Avatar
could you have air in the lines?, did you fill the filter up before putting it on?
Old May 26, 2006 | 12:23 PM
My dad just pulled in. I filled up the canister before I put it back in and now we are cracking the injector lines to see if that does anything/./
Old May 26, 2006 | 12:45 PM
Well we cracked the #1 line,#3,#4. and it started right up and rumbles like it should.. I just got air bound i guess..
Jeff
MADMATT's Avatar
on mine i had to crack 3 of them for any sort of differance to happen
Old May 26, 2006 | 12:46 PM
MADMATT's Avatar
sweet good to hear man pretty cool how this site works just got into it the past few days and wow i am liking it
happy smoking
Old May 26, 2006 | 05:17 PM
ISBpower's Avatar
what i have to do with mine is bleed the two cheak valves one on the filter housing and the other on the injection pump and then it will go.
Old May 26, 2006 | 06:14 PM
scottsjeeprolet's Avatar
In the future you need to do this and it should start right up if the LP is good.
I always refill the filter canister then install it, then get in turn the key to start and bump the starter wait till you don't hear the LP running and do it again.
Do this about 3 times before trying to start then on the 4th time try to start it.
Works for me everytime.
Good luck
Old May 26, 2006 | 06:33 PM
It worked just fine cracking three of the injector lines, It works great now. Did a few high throttle/high speed passes to make sure It was working good. He just left a little over an hour ago, So he should be good now.,The truck at about 9:00 am tomorrow will be officially not ours no more,thats if the guy keeps his decision on buying it..
Thanks all
Jeff
Old May 30, 2006 | 12:14 PM
betsycam's Avatar
Hi,
Pertaining to the truck listed below, I'm adding to this thread since I need to get mine going soon. Changed my filter but didn't have enough fuel to completely fill canister, so tried to start anyway . Started, then died. Tried to bleed at the banjo bolt, got no fuel after many many bumps. So, we got more fuel, topped off the canister, tried again, still no fuel coming out at banjo bolt after MANY more bumps. Do I go ahead and tighten the banjo bolt and move on the the injector lines? Or do I have to have fuel at the banjo bolt to proceed? I don't want to start cracking those injector lines if I need fuel at the BB; why won't fuel turn up at the BB?
Old May 30, 2006 | 01:14 PM
Can you hear the LP running when you bump the starter?
If you bump the starter the LP should run for about 20 seconds or more, if it doesn't you need a new LP.
If it does then you will probably need to crack 1,3 & 5 line @ the head and bum the starter until all of the air is out.
Don't buy another OEM pump(junk). Look for an after market one, like the one in my sig or another one, FASS seems popular on here but pricey.
good luck
scotte
