HELP! truck in limp mode, even with resistor in
Old Dec 14, 2008 | 09:20 PM
dieselfan's Avatar
i just got trans rebuilt a couple weeks ago with the help of a member.
i got a DTT TC and suncoast VB from a buddy, bought my rebuild kit and other accessorizes from HTS. billet input from OPIE.
the instructions i got from marianne(HTS) say to put a 1/4 watt resistor on the red wire in the VB. i did that. still had 2nd and 3rd gear starts when warm.
so today i install another 1/4watt resistor on the orange wire(pin 31) on the middle connector (the white one). this didnt help either.
my buddy that gave me the VB said i should have put that resistor in the vb, since he never had to.
would this make a difference?
any other ideas? did i put the resistor on the wrong wire?
also how bad is it taking off in 2nd and 3rd gear with heavy throttle?
thanks
brian
Old Dec 14, 2008 | 10:24 PM
oldblues's Avatar
hi
mine sometimes goes into a limp mode .
i simply hook up my odb2 code reader and erase the codes then the trany shifts like new agin .
give it a try ,also post the codes .
p0743 i think is the one that causes my problem .
Old Dec 15, 2008 | 01:48 PM
dieselfan's Avatar
Originally Posted by oldblues
hi
1762 was the code i pulled. gov. pressure too high or too low.
Old Dec 15, 2008 | 11:07 PM
oldblues's Avatar
hi
did you try it after erasing the code ?
can you try it with just the 1 resistor in the vb red wire after erasing code ?
if your budy never had to install resistor why do you ?
my decoder sayes voltage to low or too high making me think resistor is lowering voltage too much ?
i used a 200 ohm 1/4 watt resistor , what ohm is your resistor ?
Old Dec 16, 2008 | 07:20 AM
dieselfan's Avatar
hi
yeah i tried it after erasing the code and once it gets warm it goes into limp mode, sometimes.
i went off someone else's instructions about the resistors.
not sure on the ohm, it was higher than 200 though.
i called suncoast yesterday, they said to pull both resistors and go from there. i pulled both of them yesterday and havent drove the truck yet.
ill report back later, thanks for the replies.
Old Dec 16, 2008 | 03:25 PM
dieselfan's Avatar
Got it.
i used 630ohms worth of resistors to get my voltage to 4.5. no more 3rd gear starts
cost about $2 worth of resistors. 3 -100ohm's and 1-330ohm. with just the 3-100's it was at like 4.8, then i added the 330 it dropped to 4.5v.
thanks for the responses
03 Melt Down
May 31, 2022 12:49 PM
dodgediesel4x4
May 4, 2011 06:21 PM
Pitz
21
Jun 1, 2008 10:32 PM
tj97dodge
Jan 14, 2006 01:55 PM
danlit
14
Jan 20, 2003 06:55 AM
