Help! tranny squeaking and grinding
Old Oct 4, 2006 | 06:13 PM
1stCTD's Avatar
and making other bad noises....odd thing is it's an auto
99 2wd auto, started grinding and making a chirping sound about 10 miles from home. I thought it was the carrier/center support bearing. Replaced that and I still have the grinding/chirping/humming. The ONLY thing I can think of is the trans. It actually went away, or seemed like it went away when I popped it into neutral.
I put it up on jackstands and it's definately coming from the trans. Almost sounds/feels like its coming from the TC area.
Old Oct 4, 2006 | 06:25 PM
J BODY's Avatar
"chirping noise" from that area could be a cracked flex plate.
Old Oct 4, 2006 | 06:33 PM
1stCTD's Avatar
actually that makes sense, I noticed a slight oil or ATF leak when I was under the truck today pulling the drive shaft. If the flexplate is cracked it would allow the TC to move around a bit and take out the seal! Sound about right?
trik396
17
Nov 9, 2018 07:31 AM
barttly
Jul 21, 2012 07:53 PM
bob95065
May 6, 2008 04:13 PM
big red psd cc
Jul 27, 2005 04:53 PM
cLAYH
Feb 6, 2004 10:59 AM
