help quick!!
Old Oct 24, 2007 | 07:02 PM
ModManiac's Avatar
help quick!!
Im am putting sirius radio in my 03, and have a power supply problem. I can plug it into the cigarette lighter and the unit will come on, I then spliced the wires and put it back together that way I didnt tie up my cigarette lighter and for a cleaner install. The unit will not come on this way, what can I do!
Old Oct 24, 2007 | 07:07 PM
reecegr's Avatar
either your tied in the the neg. side or it's powered by the ignition.
Rpainter's Avatar
did you try another power source?? the cigarette light will only work when you push the lighter in completing the circuit
Old Oct 24, 2007 | 07:10 PM
reecegr's Avatar
cig. ltr has a hot wire,does not need to complete a circuit
Old Oct 24, 2007 | 07:13 PM
ModManiac's Avatar
I even tried putting the sirius radio power wire to both posts of the battieries and still nothing
Old Oct 24, 2007 | 07:21 PM
reecegr's Avatar
Unhappy
sounds like you wired it backwards at one time,hope there is a in line fuse if not you blew a resistor that is not easily fixable.
Old Oct 24, 2007 | 09:44 PM
ScottN's Avatar
Possibly fried the radio...
IIRC the reason I bought a cigarette lighter plug to install under the hood is that the radio does not use 12V, but rather 6 or 3. ... I have yet to install it under the hood, and have to plug/unplug each time I use the truck, heh.
Old Oct 25, 2007 | 12:38 AM
ModManiac's Avatar
Well guys I solved my problem, I went to Oreillys and purchased an additonal cigarette lighter and then plugged the sirius power cable into it and placed it behind the ac controls. I now am able to use both my power outlets and my sirius set up is wire free except for the three wires protruding out the back of the head unit. Thanks guys for your help.
Old Oct 25, 2007 | 10:27 PM
hink's Avatar
YEP, they won't work unless you use the supplied cigarette light plug that came with the unit. I did the same thing with mine and got the same result. Must be sumthin in the plug itself that has to be incorparated into the power supply (12v)
HorseHauler
13
Mar 12, 2006 11:48 AM
rackshakermac
Sep 8, 2003 07:28 PM
AKDSLDOG
Apr 1, 2003 02:33 AM
jet
Dec 6, 2002 09:11 AM
Haney
Nov 25, 2002 11:26 AM
