HELP! P0700, P0743, P0748, and P0753 codes
When making a 3-point-turn (probably when going from D->R->D) earlier today my check engine light came on and the transmission went in to limp mode. I checked the codes and got the following codes, all transmission related:
P0700 Transmission Control System Malfunction
P0743 Torque Converter Clutch Circuit Electrical
P0748 Pressure Control Solenoid Electrical
P0753 Shift Solenoid A Electrical
The codes come back immediately after clearning them. So far I have checked and cleaned the electrical connections at the transmission and PCM on the firewall with no luck. I did discover that it only throws the P0700 code if I leave the PCM unhooked and turn the key to the "run" position. I am suspection a bad PCM at this point. Any ideas?
THANKS!
THANKS!
Rich V
Sep 11, 2007 10:00 AM
cameroneod
May 15, 2007 07:09 AM
