Help! No Lights
Old Nov 5, 2004 | 08:52 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Help! No Lights
Hey guys, got in my truck and fired it up this am.....first thing i notice is i dont have any lights for my instrument cluster IE tach, speedo etc.
Then I notice I have no marker lights, parking lights or the back tail lights.....
I do have headlights, interior lights, blinkers (front and rear) and brake lights....
I checked all the fuses in cab and under dash cant find a burnt out one to save my life......
I noticed that the headlight swich pulls straight out like its supposed to but if you wiggle it around in a circle.....It is very loose.....
Can anyone help me? I need a fix by tonight as I am suppossed to go to north Washington from here in utah and i have to have lights...
Thanks in advance, Zack
PS...Im active duty, driving around on base the MP's are real nit picky so I could really use some help.
Old Nov 5, 2004 | 09:50 AM
TomW's Avatar
You could pull the module out and see if all the wiring is intact going into the plug. The switch itself isn't that expensive (paid 30 bucks at Autozone for it).
As for the MPs. One of those flags with a couple of stars on it should do the trick.
Old Nov 5, 2004 | 09:58 AM
zack_76401's Avatar
All the wires are intact......
Should I get an autozone one or go to the dodge house?
This is the only thing i can think of that it could be..........
Im ready to drop the money and hope it is this.....
Cmon guys im sure more people have had this prob than me......
zack
Old Nov 5, 2004 | 10:00 AM
TomW's Avatar
Auto Zone MAY let you test the new switch before pulling the trigger on the purchase. Might be an easy way to determine if it's the switch or not.
Old Nov 5, 2004 | 10:32 AM
mamm7215's Avatar
I had the same problem
It was a short in the harness in the frame near the back of the truck. B**ch to find but it was grounding out my feed for the dash lights as well.
Old Nov 5, 2004 | 12:34 PM
zack_76401's Avatar
Thanks guys it was the switch 47.10 at the dodge house,
17.99 at autozone........Somehow the connector that connects to the top of the switch had gotten hot over time and screwd up everything inside the old switch......
Thanks for your inputs.
Old Nov 6, 2004 | 10:35 PM
torquefan's Avatar
Usually too much current going thru that circuit. If you pull a trailer, make sure the trailer tail light circuit pulls the power from the trailer tow relay, and not thru the headlight switch.
Old Nov 8, 2004 | 04:13 PM
zack_76401's Avatar
It wasnt the switch....I lied it was a faulty **** that they have a TSB out on..........Anyways i have lights now..intermentitly...until sometime this week when the new **** comes in......anyone alse have this prob?
cLAYH
19
Mar 26, 2017 06:47 PM
corygale
Jul 24, 2010 11:37 AM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
