help no amps
Old May 16, 2006 | 10:03 PM
dodgedsl03's Avatar
Smile help no amps
2003 sw/sb/auto.Can drive for about 5 minutes then check guage light comes on and volt meter is dead. Then shut off for 1 minutes and is charging again little under 14. Just started today after battery died going on trip this weekend need help thanks. Shawn
Old May 19, 2006 | 10:17 AM
WSA308's Avatar
Check all connections make sure that there are no loose connectors or ground wires. Then I would suggest checking over the wire harness between the engine and the fire wall, check for possible grounding. In all likelyhood it sounds like you will need either a new Alternator or Battery.
Old May 22, 2006 | 10:24 PM
dodgedsl03's Avatar
Well cleaned connection going to alternator has not happen since hope i got lucky. 3rd Cummins none of the others left me down. just 1st 3rd gen. thanks for the in put.
doug60
Jun 29, 2005 11:22 AM
I PASS GAS
15
Mar 13, 2005 02:53 PM
durasmack
Mar 7, 2005 10:07 PM
royta
37
Dec 19, 2004 02:44 PM
dodgedude361
20
Nov 11, 2004 09:00 AM
