Help Little Brother And Friends!!!!please.
I know..I think she actually was/is waiting for someone to come and tow..but that wont happen till Monday..and then its going to be really expensive...but I think thats her only choice.I did hear that she got the plugs on and she believes it is in order..its still just getting too much fuel.I am getting off here and telling her about not turning the key all the way off etc....be back! thanx guys! Hey wouldnt that be kewel if she did manage to get it going and make it to a garage?????
To find top dead center for this purpose, pull number one plug, put your finger or thumb to block the hole, bump the starter til you get some pressure coming out. Then bring the timing mark on the damper up to the pointer going in the proper direction. Now find the wire that the distributer is pointing to and that is number one. Make sure you are going in the right direction and put the rest of the wires on.
Best to bump the starter to see which direction the damper turns and then look at the roter and bump the starter. Then you will know the right directions for both. Then bring in up to top dead center on the damper. You should be within an inch or two of the pointer. If it is past it, do it again until the mark is not to the pointer yet and then trun it the right direction to the pointer. Make sure to install the wires using the firing order in the direction the roter turns.
subspd
Feb 27, 2007 04:32 PM
dieselcrazy
May 8, 2003 11:07 PM
