Help! Fuel system depriming and leaking....
Old Jul 28, 2006 | 07:21 PM
Katmandu's Avatar
Exclamation Help! Fuel system depriming and leaking....
Subject truck is a 98 12-Valver.
My truck loses prime after sitting overnight and has a small puddle of fuel accumulated under the engine. Usually about 10-15cc or so.
Upon underhood inspection I discovered (2) parts that are disconnected. I don't know what they are and what they do.
I have yet to find the source of the fuel leak.
Can someone tell me what these parts are and what they do ??
See pics below.....
1st is obviously an electrical connector. The connector appears to be melted and not connected for sometime. Is this the fuel pump that it connects to ??
Next is a vacuum line that is located near the firewall right behind the fuel filter.
I did notice a small puddle of fuel behind the fuel pump in a valley on the engine block.
Old Jul 28, 2006 | 07:27 PM
Katmandu's Avatar
Question
Anyone know of fuel system schematics/pics (wiring and fuel lines) for my truck ? (98 12 Valver).
Old Jul 28, 2006 | 07:40 PM
Racer9's Avatar
This might help you. http://www.dodgeram.org/tech/dsl/Fac...ocations-l.gif
I'd check around the lift pump/pre-filter real good.
Old Jul 28, 2006 | 08:59 PM
Katmandu's Avatar
Question
I believe this a connector to the fuel pre-heater then correct ??
Old Jul 29, 2006 | 03:23 AM
Katmandu's Avatar
Exclamation
Anybody ??
Old Jul 29, 2006 | 07:11 AM
j-fox's Avatar
When my 95 did that very thing, I found the return line leaking. It was at the rear of the head, drivers side. There was a small crack in the steel line. I slid the hose up a little farther and it was ok.
Old Jul 29, 2006 | 11:43 AM
high country's Avatar
replace all the rubber lines and I bet your problem goes away. those lines are prone to leaking.
RiverRat2
Oct 15, 2019 10:59 AM
lilsuzuki4x4
Sep 1, 2011 01:50 AM
iamallcanadian
Mar 8, 2011 04:39 PM
nate_o23
Feb 28, 2009 03:34 PM
Ghost Ram
21
Feb 2, 2008 12:33 PM
