help fuel filter
help fuel filter
i just changed the fuel filter, right after i started it an ran fine but had no fp. then it died and wont start. ive bumped the key to run the lp a couple times, but it still just cranks. ??? what is the procedure to get her going agian?
Crank several injector lines , usually I just do the easy ones to get to, and crank until you get a pretty good stream of fuel. The tighten them back up. Should start and run rough for a bit, then smooth out. You can also try cranking some more, but careful not to get the starter too hot.
If you dont have a fuel pressure guage - changing fuel filters is a great way to find out that your lift pump is dead.
Do you have a fuel pressure guage? Are you seeing any pressure at all?
If you have pressure, you are air bound and need to crack injectors...(#1, 4 and 5). If ou dont have fuel pressure, then its time for a lift pump upgrade.
Good luck.
Good luck.
i have a guage and i have no pressure. i have bumped the starter many times, just to get the lift pump going and i can hear it, but it still wont fire. should i get a factory lift pump or a raptor or somthing along lines?
thanks
thanks
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
If needed, get a Raptor. Factory replacement just doesn't give you any extra fuel, is unreliable and expensive. For just a little bit more money, you can buy a reliable, higher performace Raptor.
Happend to a friend a few months ago. 4 year old fuel filter. I ended up having to bleed all lines( plus checking for pressure) I had to crack all 6 lines at the injectors,(one at a time) then she fired up and purred like a kitten...
I would loosen the top on the fuel filter first, then turn key to run, repeat until fuel comes out the filter top, quick tighten on the cap, then key to run, then try to fire it..... take it easy on the batteries or you will kill them faster than you get it running, hope you have jumper cables and a sturdy steed ready to give you a boost to get it running, last resort is crackin an injector line stay well clear of fuel comin out, it can come out at a lethal force.
Its easy, but i would go through the procedures Mikmaze said, ( kinda what i did) Nothin worked so i cracked one injector line at a time. Once cracked, turn motor over and fuel should squirt out, tighten and go to the next. Piece of cake.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
