Help dead peddel after vp44 install
Old Sep 4, 2006 | 06:11 PM
jaymo's Avatar
Just got done putting in the new vp44 and got it started idles fine but the go peddal does nothing! Am going to do the apps reset hopefully that does it. also replaced the cam sencer.If this helps any.Also the check engiene lite is on now.
Old Sep 4, 2006 | 06:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
If that doesn't help, double check the harness multi-connector to the APPS.
Old Sep 4, 2006 | 06:37 PM
jaymo's Avatar
Dam never thought of that Ill check now...Thanks.
Old Sep 4, 2006 | 06:39 PM
dodgetech77's Avatar
Did you plug the sensor back in?
Old Sep 4, 2006 | 06:48 PM
jaymo's Avatar
Yea I did , But I used some (Dielectric) sealent. Hopefully its making contact.
sp?
But it does start and Idle just no go peddel.?!
Old Sep 4, 2006 | 06:51 PM
Scubasteve's Avatar
Not to be a clown but did you get the cable hooked up as well?
I would double check the plug on the APPS as well. It worked before unless you got a bad pump out of the box.
Jason
Old Sep 4, 2006 | 07:31 PM
jaymo's Avatar
Well that was the problame. The apps plug was not plugged In . It started to rain when I was finnishing and I overlooked it. Thanks alot for the help. She seems to be running really good. Now mabee I can break the 400 hp mark.
Again this site rocks !!!!! and thanks
Old Sep 4, 2006 | 07:41 PM
Shovelhead's Avatar
It's always the simple stuff that teaches us humility.........
Glad to hear it's running again.
turbos10
25
Dec 14, 2010 10:56 AM
MikeyT
15
Oct 2, 2008 01:22 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
cmckinney
43
Mar 16, 2006 04:13 PM
