help coolant leak.
Old Nov 18, 2007 | 07:34 PM
dj_souvlaki's Avatar
help coolant leak.
seems to be comming from the front of the truck on the passanger side just behind the bumper.
noticed it about 1 day after i cleaned out my clogged rad. used a garden hose and engine shampoo.
topped up the coolant. maybe i bit a bit too much and its just overfilled and comming out. took a peak earlier and could see anything leaking. any common places for these to leak?
Old Nov 19, 2007 | 12:53 PM
91.5 beater's Avatar
One of my water pump bolts broke and i had to take it off cause it would leak coolent. If it is a waterpump leaking you should take it off cause i bet you have the same problem. Taking the bolt out of the block is a real fun job that requires lots of patience and cussing. If it is the pump it will be dripping off of the a/c compressor, so you ought to crawl under there and see if it is. mine is a first gen but they have the same w/p and hardware.
Old Nov 20, 2007 | 12:35 PM
well i have my warranty thankfully lol.
heres the trippy part. it only leaks sometimes. i might go on a 20 min drive to work nothing. i go on a 20 min drive home nothing. i go on a 20 min drive to grab a beer with friends then i see it after i shut the truck off.
its a weird one lol.
Old Nov 20, 2007 | 12:52 PM
mine only did it when the a/c was on
Old Nov 20, 2007 | 07:59 PM
*scratches head* well its cold here so i have no need to turn the a/c on. hmm does a/c come on when defrost is selected?
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
george7941
Nov 28, 2009 09:28 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
