Help with air conditioning
I'm trying to figure out what is wrong with my air conditioning
It is blowing cold but only out of the floor and defrost vents, it will not blow out of the dash vents. AND it will only work (Heater and Air Conditioning) on Low or High, nothing in between.
Anyone one else had this Problem? Or know what it could be?
I had my air conditioner blowing out defrost vents only and it ended up being a leak in the vacuum line right before it came into the cab on passenger side. The vacuum line was rubbing on transmission dipstick and had a hole wore in it .
I 2nd the vacume leak, in a hose or the control pannel , the fan is probubly the resistor for the speed control .
This is one of those best help with having a factory manual .
jlbrown
18
09-18-2007 08:54 PM
