help with 83 suburban
Old Apr 22, 2006 | 09:14 PM
H2SRDMB's Avatar
im replacing the bearings on a 83 3/4 ton 4x4..
i set then down all in order. and my friends wife wanted to help. mixed everything up. need to know the order to put the hub back to gether.. schematic etc..
thanks in advance queeg
Old Apr 22, 2006 | 09:51 PM
RCW's Avatar
RCW
Do a search of the Net with the term "rebuild" and the model of the GM differential on which you are working, there are a number of sites with full schematics available.
Old Apr 22, 2006 | 10:18 PM
blackdiesel's Avatar
Registered
inter & outer bearings of corse then the axle nut with the tit on it (tit out) then the washer with all the tit holes in it (BE SURE that the tit gos in one of the holes [this could take a while]) then the 2nd nut (tighten the 2nd nut good) then there is a thin shield thats bigger that the spring sets on then the spring then the two locking peices (big one first then the little one that splines on the inter axle) (the big one splines on the hub) put on the snap ring on the axle (you might have to push the axle forward with a screw driver in the u-joint) then comes the out side piece with the threaded holes in it that holds the outside hub on then put in the outside snap ring and bolt on the hub and that should be it. thats the longest sentence I have ever seen that dosent really make sence. (well it does to me anyways)
Old Apr 23, 2006 | 04:05 AM
H2SRDMB's Avatar
awsome ... thanx. went back together easily with the correct order! i tried looking onlineearlier but then my laptop battery went dead. now time to sleep goodnight and many thanx again
red12valve
Cummins Conversions
Mar 19, 2011 09:41 AM
dodgedriver
Mar 21, 2004 10:35 AM
JyRO
Dec 23, 2003 10:40 PM
AZGEARPRO
Dec 11, 2003 07:48 AM
Iron Mike
Oct 17, 2003 12:15 AM
