Need help with Suburban conversion
Old Mar 1, 2011 | 07:12 PM
red12valve's Avatar
I got started into the middle of someone elses project and am looking for some advise. Heres what I have: 86 Suburban body (was a 6.2), on a 92 3/4 ton Dodge frame, 4x4, auto. The person who started the project seemed to do a pretty good job. About all that was done was mounting the body to the frame. The entire suburban wiring harness is there. The entire front half of the dodge harness is there w/ the ecu. I picked up where I could and mounted radiator/ intercooler and started wiring. I do not have a lot of experience with 1st gen dodge drivetrain. From what I read it is an overdrive trans, right? If so what do I need to make the trans shift? Does it have a lockup convertor? As far as the engine goes the only thing necessary is to power up the fuel shut off solenoid? I can use guage sending units for the burban and reuse the factory burban guages. What do I actually need for wiring? Any information would be greatly appreciated.
Old Mar 8, 2011 | 07:38 AM
Greguw's Avatar
You can try the 4btswap site ... there is a lots of info there . most guys use the original chevy frame , its very similar to the 1st gen dodges .
You can retain the original gauges , just get a wiring diagram , I think the solid green is the water temp , tan I think is oil pressure ... its pretty easy just takes lots of time ... and some moo la also .
Here is my build , I got a little more carried away with my build ... going to keep it simple with manual fuel shut off , nv4500 , 205 transfer ... it will have air and power windows .
http://67-72chevytrucks.com/vboard/s...d.php?t=411609
greg
Old Mar 19, 2011 | 09:41 AM
dieselJon's Avatar
OD works by grounding one of the wires.
3 wires needed for it to run, the fuel shutdown solenoid, starter wire, and OD ground for it to work.
Head over to the 1st Gen section and ask away.
BTW, no lock up.
Gerry M
Feb 5, 2010 09:26 AM
H2SRDMB
Apr 23, 2006 04:05 AM
AZGEARPRO
Dec 11, 2003 07:48 AM
Iron Mike
Oct 17, 2003 12:15 AM
