help 2002 power loss
Old May 18, 2010 | 09:47 AM
blue2002's Avatar
Have edge attitude. I change it from level one to level five and no difference and no extra smoke. It smokes bearly and not white if I am off in it. Its a 2002 6 ho. It used to run great but all of a sudden its like lacking power. I get like 15 psi of boost going up hill. It doesn't speed up real fast to the floor. The egt is about 800 going down the highway at 70. Do yall have any suggestions.I have 20 psi on fuel and never drops down below 15 sometimes it doesn't even change.[dummy
Old May 18, 2010 | 10:17 AM
rebal's Avatar
have you unplugged the Edge? it could be the problem also check the codes how about fuel filter? is your fuel pressure tested at the VP? or before the filter?
Old May 18, 2010 | 11:44 AM
blue2002's Avatar
I have checked the codes there are no codes at all. ya the pressure is mesured by the attitude monitor. I just changed the filters about 1000 miles ago. I haven't unpluged the from the truck.
Old May 18, 2010 | 12:55 PM
kantdrive55's Avatar
DTR Advertiser
check the tap on the pump wire as well. If that comes loose you cut your power in half.
Old May 18, 2010 | 01:45 PM
RowJ's Avatar
If above does not help....disconnect the Edge completely.
If that solves the acceleration problem, you have your culprit! (But sounds like your wire tap)
Edge use to have a fair # of failures. Haven't read about too many lately but you need to diagnose one possibility at a time.
Other possibilities- Air blockage (rare)...... fuel blockage (already mentioned)..... starting to have VP-44 problems. I had one that ran normally, with no codes at all, but just would not dyno over 400 hp.
750*- 800* at cruise (level ground and no wind) is normal. What's the boost reading?
RJ
Old May 18, 2010 | 06:25 PM
blue2002's Avatar
its reading like up to 15 if i hammer it. it used to do 40. it drives like the turbo is not working.
Old May 21, 2010 | 08:44 AM
blue2002's Avatar
thanks everyone it was the chip. have to send it off for repairs
Old May 21, 2010 | 10:15 AM
rebal's Avatar
Thank you for posting what it was ,that lets us know we were shooting in the right area
all the info helps us help others.
Old May 21, 2010 | 10:23 AM
RowJ's Avatar
Ditto! Good point. Too often we never hear if we are on the right advice track!
RJ
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
chris2@eotnet.n
17
Nov 29, 2006 02:10 PM
Ranger 2/75
Mar 16, 2006 05:07 PM
