Heater Control
Old Nov 20, 2003 | 06:56 AM
DRESSER DAVE's Avatar
Heater Control
Good Morning From Detroit and its getting cold up here,I have a 2000 2500 CTD and my heater,vent,defrost mode is stuck in the defrost position,hot to cold seems to work fine,just wont switch from defrost to heat or vent,possible vacuum swith?
Old Nov 20, 2003 | 07:51 AM
kandgo's Avatar
Re:Heater Control
Hello,Dresserave, I had the same thing happen,went looking for the problem,ie; vacum,stuck valve,turned out it ws simply the **** itself was broke,it was craked inside and would just turn,hope it is the same for you!! Good luck Rick
Old Nov 20, 2003 | 08:13 AM
MnTom's Avatar
Re:Heater Control
That could also be a vaccum leak. The heater controls are designed to go to defrost as a "default" position when there is insufficient vaccum. Does your cruise work like it should? If it doesn't then there is a leak somewhere. There has been problems noted under the left battery tray.
Tom
Old Nov 20, 2003 | 08:52 AM
Re:Heater Control
I thought the same thing Tom,cruise works fine,I am leaning twords the actuator ,thanks for your input.
Old Nov 20, 2003 | 12:49 PM
Zino's Avatar
Re:Heater Control
Not sure about 2000, but my 2001 cruise control is completely electronic and has no vacuum control.
Zino
Old Nov 20, 2003 | 04:39 PM
barracuda's Avatar
Re:Heater Control
mine did the same exact thing...Here's your problem i would bet. Their is a thin hard-lined plastic vacuum line that runs from the driver's side to the passenger side on the fire-wall...it's high up near the top...check it for a small hole or crack ( check it good, i used soapy water to find the hole on mine )...i fixed that line and everything worked again...same symptoms as u r having..
SolarYellow05
Jun 22, 2006 04:55 PM
grizzly660fan
Jan 2, 2004 10:02 AM
TexasDiesel
Dec 27, 2002 10:47 AM
