Head gasket 96-12 valve. Time involved??
Old Mar 21, 2006 | 10:03 PM
Ram of Steel's Avatar
Title says it. I just last week installed new valve springs and an engine brake. I also repaired the leak at my T/stat housing and now one week from a trip to Death Valley with the monster 5'er from Hell I find an external coolant leak at the head gasket near the T/stat housing.
I do not have a time guide but I do have the proper tools and many years of unfortunate automotive experience. What kind of time can I expect to replace the head gasket? The odometer reads 199,995 miles.
Many Thanks!
Old Mar 21, 2006 | 10:07 PM
Crimedog's Avatar
If you have all the parts you need, it can be done in a long day by yourself, or a weekend with lots of breaks. However you will want to have an appointment already set up to have the head checked, which is highly recommended. I took a gamble when I had the leak from the same spot, I just threw a new gasket and some studs on and hoped for the best. Been fine ever since, but if I had the choice I wouldn't play with fire again. You're better off just getting an upper gasket kit from cummins, that way you have everything you need. Good luck
Old Mar 21, 2006 | 10:16 PM
Thanks.
I have a machine shop two doors down from where I will be doing the work.
I try and get as many parts directly from Cummins as I can. I'm lucky to have "Cummins West" about an hour away.
R.O.Steel
ted_pulliam
Jul 16, 2009 11:33 AM
rebel5422
Apr 11, 2008 04:41 PM
wildchild97
Sep 25, 2007 02:44 PM
Diesel-Dan
0
Jul 26, 2004 03:27 PM
mr T
Mar 15, 2004 08:30 AM
