Hard starting
Old Jul 27, 2008 | 03:52 PM
Barry Smith's Avatar
Hard starting
I just replaced my VP-44 and APPS. The truck still has to turn over alot before it fires up? I have good fuel pressure at guage but slow starting. Air leak somewhere between fuel filter and VP? When I was bleeding the fuel line I cracked just injector #1. Any help or ideas would be appreciated.
Old Jul 27, 2008 | 04:42 PM
2500Ram's Avatar
When did you replace the VP? Minutes ago or miles ago? When my VP was replaced I had slow FP readings for about the first 30 seconds but never a hard start. Could be air in the lines if you just replaced it, not many miles. Otherwise I'd start looking at the return lines from the VP. They don't leak but will allow air into the system and cause a hard start.
Good luck.
Old Jul 28, 2008 | 10:45 AM
PChouinard's Avatar
Check around the fuel heater, on top of the fuel filter assy, for any seepage. The oring around the heater gets bad and will allow just enough air in over night to cause hard/no start.
Old Jul 29, 2008 | 11:09 PM
ET RAM's Avatar
Make sure your starter system is good to go. I had the same problem and it was the starter.
Check these threads out.
https://www.dieseltruckresource.com/...d.php?t=184920
https://www.dieseltruckresource.com/...d.php?t=209551
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
L. D. Bryant
Nov 17, 2002 12:18 PM
