Hard starting 1838 uniloader need some help
Old Aug 30, 2005 | 07:09 PM
Dufrain's Avatar
We have a Case 1838 uniloader with a Kubota diesel.It starts ok cold but wont start after its warmed up. Would you guys have any suggestions on what to check,thanx alot
Old Aug 30, 2005 | 09:47 PM
Rare1's Avatar
My 2 cents: leaking injectors. Do diesels flood and refuse to start?
Old Aug 30, 2005 | 09:48 PM
Dufrain's Avatar
I dont see them leaking externally
Old Aug 30, 2005 | 11:47 PM
pind's Avatar
If your kubota is like most, it should have a 12VDC lift pump, that looks much like a fuel filter. its a plunger style pump. I have seen kubotas have warm start problems if this pump goes out. Also, check for hot areas on the inlet side, if there is a high spot in the lines.
Good luck with it
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
big builder
37
Dec 12, 2007 07:07 PM
abc4yew
Mar 15, 2007 11:55 PM
NY_MEDIC
Sep 15, 2003 02:38 AM
