hard start when hot.
I have a 1998 dodge with a 5.9 cummins in it .when the engine is cold it starts good .it runs good with no codes .when you shut it off lut it set for a little bit it dont start vary well .after you get it running it runs good.
Ok, new info.
Hard starting like that could mean a bad injector, or a VP going out. The fuel pumps (VP, high pressure) in these trucks have a high failure rate, especially when they are starved for fuel (lift pump going bad).
Do you have a low pressure fuel gauge?
You've got good low side pressure.
If I remember, I think that a bad injector won't crank when it's cold...
Time to start asking VP questions. I'm not a second gen guy... that's the best I can offer you.
Check this out, too. Could be the computer on your VP...
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Strjock81
16
Dec 12, 2007 09:53 AM
duallydave
Aug 7, 2005 09:38 PM
