Grinding Going Into Reverse
Old Apr 25, 2006 | 09:13 PM
EDDIEKLUMP's Avatar
Exclamation Grinding Going Into Reverse
I Changed Throw Out Bearing And Master Cylinder On CluTch Now It Grinds Going Into Reverse? Is There Any Thing To AdJust? Thx Eddie
2002 4x4 2500 6 SPEED 24 VALVE CUMMINS
Old Apr 26, 2006 | 09:48 PM
RCW's Avatar
RCW
When this happens it is usually due to air in the clutch hydraulic system keeping the slave from fully releasing the throwout bearing. Do the complete dunk and bleed procedure if you have an OEM clutch system, or do a simple bleed if you have on of the much better (and half the price) rebuildable units from the aftermarket.
primepedaler
May 4, 2006 05:47 PM
plnmkr
45
Jan 3, 2006 10:03 PM
stonewalldiesel
Aug 26, 2004 11:16 AM
cLAYH
Feb 6, 2004 10:59 AM
angus
Feb 6, 2003 09:16 PM
