Grind under load.
Old Jan 24, 2003 | 06:15 PM
Wilson's Avatar
Grind under load.
My buddy has a dodge with an auto tranny and a v10. Anyways, it has developed a problem recently that I hope someone can help me advise on. Whenever it is under any kind of load it seems to pop out of gear or something, and it makes a grinding sound like when you miss a gear in a manual tranny. It can happen while accelerating from a standstill or while moving and pushing the go pedal a bit. Once you take your foot of the accelerator it stops. Anyone had a similar problem? <br>thanks in advance
Old Jan 24, 2003 | 06:29 PM
gofastman's Avatar
Re:Grind under load.
Sounds like a yoke stripped out or its in the rear end.<br>Possibly planetary gears in tranny, but im not sure on that one.<br>Whatever...I would get it figured out and not drive it anymore, so not to do any more damage.<br>Allen
Old Jan 27, 2003 | 09:32 AM
Wilson's Avatar
My buddy says he has towed some pretty heavy stuff, but never had a problem and this began happening while he was just driving thru town with no weight or anything. I think it may be the shaft also but we will see. thanks for the help.
Old Feb 6, 2003 | 06:28 PM
Wilson's Avatar
Scott,<br>You were correct, a broken snap ring. Im glad it wasnt his trans. a snap ring is a little easier. If anyone else out there ever hears an sound like that, now you know.<br>thanks again scott.
Old Feb 7, 2003 | 06:27 PM
Wilson's Avatar
I think I if it happens again I will recommend him getting the same conversion kit that you did. I mean why fix it if you can make it better right?<br>Thanks again
Old Dec 18, 2006 | 12:47 AM
NWDodge's Avatar
Similar problem
I am having similar sounds.........also does it if I hit a bump. Would this be an indication of a broken snap ring? Thanks
Satman30
May 28, 2008 01:48 PM
Firstgenfanatic
Apr 10, 2008 12:24 PM
carwash
Sep 12, 2007 11:39 AM
Dodgezilla
Feb 13, 2004 03:40 PM
JM_1
Dec 23, 2003 09:23 AM
